- Apr 18, 1999
I have had my Carnivore since March of this year. Shortly after I received it the blade stop pin began to rattle. I read in the Forums where others had experienced the same problem and solved it with a dab of silicone caulk. I too remedied my rattle in this manner. However, now I am experiencing some vertical blade play. It appears to be due to some play in the blade stop pin. It does not rattle but I can move it with a paper clip. Depending on where the pin rests in its little holes, the blade has verticle blade play.
Do you folks see this as a super glue fix or should I contact REKAT and perhaps get a properly sized blade stop pin. While I could tolerate the rattle if I had to, I cannot abide a loose blade on a knife that costs as much as this one did.
Thanks in advance for any advice you can give me.
Willieboy
Willieboy
