Case Peanut Spring Strength
Hey guys. Is is normal for case peanuts to have very stiff springs? I was given one some years back by my uncle and its been in a drawer ever since. Tonight I got it out to put on my desk for opening mail, and I noticed the stiff springs. They are both stiff, but the pen blade seems excpetionally so to me. What do you think? Send it back?
I have a few Case Peanuts, and they are firm but not overly stiff. You might try a small drop of lube on the pivot and work it in real good just to see if that loosens it up a little.
Tried that and it didn't really seem to help. When I say stiff, I mean like I can hardly open it stiff. Its a nail breaker. Literally.
There is always the exception to the rule, but typically Case knives don't have springs that are nail breakers. Out of all the Case knives I have now, or had in the past, only one would be considered a nail breaker. It also happens to be one of my favorite knives.
If it is so difficult to open that you won't want to carry it because of that, I would send it back to Case. They will take care of you
i bought my dad his first quality pocket knife last year, A yeller CV peanut and it's a bit like a gator, but not overly so. It walks and talks with authority!
But not hard to open
cheers
ivan
Thanks for the advice guys. I currently own 6 other case knives, but only one peanut. The springs on all the rest seem very good, but they are all larger patterns so I can't say if they are really a fair comparison. I didn't know if this was normal for these little guys. I will definitely be sending it back.
Two Case peanuts and neither are 'nail breakers.' One is a 5 and the other a solid 6 on spring pressure.
What works for me is:
Oil the joint
Wrap the blade in a paper
Open and close the blade for 1/2 hour
If it is still a nail breaker, send it back to Case
I never thought about it much until I replied earlier in the thread, but after thinking it through, the Case knives I have had that had the strongest springs were knives that also had half stops... :confused: With the exception of one early 6375 that is a bonafide nail breaker... Its getting better the more I work it though
Coincidence ???
Oil the joint
neeman, this is exactly what I spent this evening doing. I turned on the football game and worked away. No avail. The pen blade is still a killer. Its going back.
My buddie at work has a ducks unlimited Case peanut and it walks and talks with authority too. Has a nice ring to it and its not really hard to open.
I always find the pen blade on my Case Peanuts and Barlows stiff to open but not a nail-breaker, guess its just got less leverage because of its size? But the clip is easy to open.
It might also be a matter of getting used to. Not only are the springs on the Peanut stiff, but the small size of not only the blade surface/nail nick area, but of the handle to hold it, make it difficult to hold/open at the same time. If you don;t send it back, work on it for a little while. It just might take some practice. I was always scared to open the pen blade on my peanut because I was always afraid I would slip, it would shut, and cut my finger.
Hey guys. Is is normal for case peanuts to have very stiff springs? ... They are both stiff, but the pen blade seems excpetionally so to me.
The tension of the spring on the pen blade is the one thing I'd change about my 'nut if I could.
I can open my Case peanut's clip blade without using my nail. The pen blade is more difficult but not a nail breaker.
I have 2 Case Peanuts, one in derlin SS and one in yellow CV. The derlin one was a bit stiff at first but not much more than an alox SAK, it let up after a bit of use. The yellow CV peanut was not stiff out of the box. I think it is a fine tension for a small knife. My preference is for lighter tension on slippies due to my weaker, thin nails.
Of all the peanuts I've had, I think I would desribe them as firm, but not hard to open. Most were pretty close, but I did have one that tool a lot to get it to the first step of the half stop, but I did send it back to Case, and the knife they sent back was easier to open.
I think like most things production, there is a window of acceptable tollerences, and some knives get through with a bit stiffer springs.
