- Aug 27, 2004
My friend Joe Caswell and I have been talking a lot lately. We met a while back here on the forums and one of the reasons I contacted him of course was because of the article in Tactical knives covering his wonderul little folder the EDC which is has a neat pocket clip invention incorporated into it which Joe came up with. After congratulating him on the article being published we got to know each other a little and in the end I ended up snagging one of the EDC folders for myself. I kind of knew already that he had a lot of the same ideals in what the most useful handle shape was as well as a few other things since I saw similarity in the way we each separately designed and built our own folders.
This is a liner lock the way they should be made folks! .080 thickness titanium liners, and no lock cuts to spring the lock! EDIT: I just removed the lock side scale for the first time to check out the inside of my EDC. Turns out there are 'unconventional' lock recesses milled into the lock side at the end of the long cut for the lock but they are nothing typical of what you see in most thicker frame locks or liner lock folders. The visible portion is left untouched. There are two milled out circular spots to different depths on the outside of the ti lock side at the end of the lock long cut which would be covered up by the scale. It would be more accurate to say there are no 'visible' lock cuts on the .080 lock the way Joe does this one. I am not sure how deep the deepest end mill goes but the higher milled out spot goes down deeper and the one below it goes down just about half the depth of the first one with the visible end full thickness up to about 1/8" or so plus or minus. Just thought I'd better correct that statement. I bought mine just like the one I saw in the centerfold in the Sept. 08 article from Tac knives. I loved the look of the handle scales in that article and now that I have one of my own I love them even more! This is flat out without a doubt the best texturing of anything I have ever handled on a folding knife! I like it so much that it alone makes putting the folder down something that I have not been able to do since buying it. I must say though, I also love the blade Joe did here in damasteel. The stainless damascus is a great idea anyway, but with the Bos heat treating I'm sure it steps it up a notch.
I have not really used mine much to speak about edge keeping but I am sure its a great blade with the experienced hand that created it and the science master that heat treated it.
Here are some shots all around for you guys that have not seen this. I can't say that I have taken to the clip completely just yet but its for sure a great idea. I do like it a lot and the clip is certainly tolerable for me. Its just different is all but once you get used to it I think its about like anything else. It grows on you.
Joe, great folder man. I gotta hand it to ya. You knocked one out of the park with this baby!
My example of Joes fine work weighs in at 4.2 ounces, has a 4.5" closed length and a 3.25" blade. Overall the folder is flawless through and through. I cannot say enough good about these textured micarta scales. Just simply the best I've ever handled. I'd love to have lots of it in multi colors and both in Micarta and G10 in my shop as something I could offer my own customers and use for myself.
STR
STR
