They probably don't know, though they've probably discussed it with a forum member who actually visited their warehouse. They make stones for industrial machinists, polishing plastic molds, dies and machine parts. And, some are meant for hand use but others for ultrasonic profiling machines (too hard and slow for hand use).
I got an assortment of them a few years ago to experiment with as hand files for sharpening small curved blades and started mentioning them (along with the Boride Gesswien and Falcon stones) to Thom and Curtis et. al. as replacements for edge-pro stones (think Ben used a Boride AM on one of his hones). Someone was complaining about the Sharpmaker and I mentioned that the 1/2' stones were exactly the same width as the sharpmaker rods so thought the triangle stones should fit the Sharpmaker (less an inch in length), and mentioned that I liked the smooth, even finish the flex-cut leaves, and the aggressiveness of the Ruby (though they wear faster than some of the others).
So, they and a few other people started ordering different stones and grits to try out in a Sharpmaker (I bet the poor folks at Congress never thought of using them as sharpening stones and probably thought it was a full moon when all these crazy knife nuts started showing up at their door wanting 1/2" triangle rods). Turns out they worked quite well, especially the Ruby (and I think it was the moldmaster?). Use the flats, the corners have not been smoothed and are too jagged, though you could probably round and smooth the corners a bit on a diamond plate if you are really intent on using the corners.
Here is the thread that started the sharpmaker thing
http://www.bladeforums.com/forums/showthread.php?t=444326&highlight=Congress
