How possible is it to make a convex beveled production knife? Easy as anything else, or not likely with standard grinding equipment? A hollow grind seems like the natural result of a grinding wheel, but a convex grind is the opposite.
IMO, the "perfect knife" would be a slight convex grind, rather than flat, with the main bevel going down to near-zero (ie, very little edge bevel).
Lots of custom makers like convex edges, but full convex bevels are so non-existant that I sort of put them out of my head until it was mentioned in another thread. The large bevel is really the same as the bevel that makes the edge, just larger and one level up. Why not apply the same rules?
This type of blade would give you more strength towards the center of the blade (unlike full flat or hollow, which put the strength at the spine), while having minimal evvect on the angle and thickness near the edge. A partial bevel (like a delica) is OK with a wide enough blade, but still sacrificing cutting ability with the sharp hump running down the side of the blade.
It I will never be able to get such a knife, I suppose it wouldn't be hard to modify a partial flat grind.
