- Mar 5, 2001
Nope, not a "how do you do it?" post.
Just did a convex on a 52100 blade. Have learned how to in all other grinds and have some very sharp blades.
But this convex shape is something else. Stayed away from it for several years thinking I would not be able to, but used two mouse pads and dry sandpaper and am totally impressed
ie Big smile.
Had to drop to 400 grit to get an initial burr on the edge length, then up to 1000, 200 at a time. (note: original blade came not so sharp).
Didn't take that long (about 1 hour) and is only my first try. Right now will part cigarete paper (edge or width) as though not there. Chopped some wood and other odds and ends and then stropped it on a leather jacket sleeve and that is all it took. Am beginning to delude myself that I may actually have a knack for free hand sharpeninng. Still, have read many say that convex is the easiest to sharpen and keep sharp, even out in the field.
Think I can do better the next time (more practice) and wonder what going up to 2000 grit will bring.
Question though (dumb one). When doing the the tip (upswept after the belly)? Should I be turning the blade to be perpindicular to the grind as normal sharpening or keep the blade straight. Is only the last 1/2" of the tip that is not super sharp right now.
Rad
Rad
