Before I got my EdgePro, I turned my Lansky into a min-EdgePro. Never did like the knife clamping thing. Anyhow, I took a think piece of aluminum and clammped that into the Lansky, so that it stuck out to support the blade but not go past the edge of the blade. I used that as a rest for my blade, and just did the flip over thing. I had to cut a slot in the aluminum piece I used to accomodate the screw on the Lansky.
I also clammped the bottom part (the other side with the degree holes) of the Lanksy into my vise to hold it steady. The little diamond hones did a pretty good job of profiling. Then it was just a few minutes to get a good edge.
You could easily rig something like that up and use Eze-Lap 1" x 6" hones or the three piece pocket set from Smokey Mountain Knife Works.
Or prop your hone up at an angle and do the Sharpmaker thing by keeping the blade vertical and pulling it down your now angled hone.
It was fun to tinker.
mike
