CRK&T Lg. KFF...Initial Impressions
First let me state that photographs or scans do not do this knife justice. It is one BIG honkin' folder! When you stumble across it in the display case of your local cutlery dealer, it reaches out and snatches your attention to it because of it's size. It is a formidable folder.
The first thing after the initial shock of seeing this beast in the flesh, you'll want to compare it to a comparable folder. In this case, I immediately thought of the REKAT Carnivour. These two look like they could be brothers, except for the fact that the KFF out-sizes and out-masses the Carnivour. The KFF is a heavy knife. So heavy it feels to be the about the same weight as my Sifu or maybe even a shade heavier when I compared the two together.
This is due, I believe, to the very beefy metal spacer on the back of the knife.
Balance of the knife is right at the finger cutout and the blade has an almost distal taper to it. I say almost because the taper starts at about the half way point down the length of the blade and smoothly tapers from that point down to the tip. The edge is kind of thin but furhter up the spine it kind of quickly thickens to just over 1/8" thickness. The grind looks nearly the same as that found on my lg. Microtech M/A SOCOM. Servicable, but not what you would call acutely thin. The edge, OOB, is extremely sharp and polished and pops hair on the arm with ease. The blade shape is a strong clip that is made for action and centers along the middle of the handle. The blade also has a rather good belly to it. A surprise given the strong clip profile of the blade. This is because the blade is 1 3/8" wide. Quite a handful.
The handle is, dare I say(?), more comfortable than my Carnivour. The standard by which I judge the comfort of other folding knives. It fits my hand so well that it feels as if it were made especially for me. The handle is designed in such a way as to virtually eliminate that clip pinch that often times accompanies folders with pocket clips attatched to them. One can hardly tell the clip is even there. You can feel it, but it's not uncomfortable on the hand.
Now for the good stuff, the lock.
The liner lock readily passes the Spine Whack test, even without engaging the L.A.W.K.S. safety mechanism. Once that is engaged, the thing becomes almost a fixed blade. The lever that engages the safety mech. is in the way just a little when you have it engaged and your thumb is riding on the blade spine, but the discomfort is minimal and is easily overcome by moving the thumb a little furhter up the spine of the blade.
Conclusions:
The one and only weak spot in this knife is, IMO, the choice of blade steel. This knife is such a winner that it easily deserves a better blade steel. Even AUS-8A would be an improvement. BUT, if you intend on this knife to serve only in a defensive capacity, and not for utility, then by all means, go get one NOW!. The steel used is AUS-6M. Not a really bad steel, it just needs sharpening a little more often than 8A or 440C, for example.
All in all, IMO, this knife is the new reigning champion of the "Best Bang for the Buck" Award. There is no knife on the market right now, that gives all the positive features that this knife does at this incredibly low price.(Less than $45.00)! It is truly a stand out design and I for one, would gladly take it with me if I had to go into unfriendly environs.
The extremely high overall quality and the extremely fair price of this folder put it in to a category that few other folders can go. It's quality is such that it inspires a great deal of confidence in it and the price is so reasonable that it won't break your budget or your heart if it needs to get tossed or even gets lost.
I am, initially, very happy with this knife.
I will be testing the edge retention tomorrow.
Happy Trails!
The individualist without strategy who takes opponents lightly will inevitably become the captive of others.
Sun Tzu
[This message has been edited by misque (edited 04-27-2000).]
misque,
Great review! I have custom KFFs and love them. The handle is wonderful. I'm thinking about getting the CRKT version as a backup to my customs.
Kevin Gentile is working on a modified version with a recessed liner lock, cut down LAWKS and action job. He will also grind down the edge to make a trainer.
Axel
I've got to agree with everything misque said about this knife. I've had it for a week, and it is now my daily carry.
-Travis
Sing,
Greetings! Kevin Gentile is the resident knifehead at Gun Ho Chuan. He does the custom work on the BM AFCK's that Kasper uses in some of his classes. His address is:
www.ghca.org/knifehead.html
Mario
Gaucho
Tuvo muy mala suerte...se callo en mi cuchillo.
I cant wait to see the edge retention tests. I agree that this is an awesome knife. Excellent quality for the money. I am not pleased with the choice of steel. I would like to have at least seen AUS-8.
Dennis Bible
The knife seems extremely well made. Like Shootist16 I am interested in how the edge retention / corrosion resistance / durability of the blade is. The overall design is a proven winner and the materials and contruction seem top notch (would also have like AUS8 steel).
My first impression?
Gee, what a big Honkinfolder!
This knife makes my large CRKT M16-04 seem like a small knife
Kevin
Kevin Pensinger
The EDGE Equipment
sales@theedgeequipment.com
Contact The EDGE for your custom cutlery needs!
Yep,
CRK&T is surprising me on a regular basis these last few months.
I've been carrying it for about a week now and it becomes more dear to me with each passing day.
One minor glitch I'm finding is now when I'm messin' with my other folders from other manufacturers, I find myself reaching up to engage that L.A.W.K.S. mechanism and guess what?! It AIN'T there!
Sun Tzu
I got some Timberline Wortacs in. Similar construction to the KFF but AUS-8. The handles are also more comfortable to me. I believe this may give the KFF a run for the money.
Dennis Bible
....Almost here, The Leading Edge....
http://www.theleadingedgeonline.com
[This message has been edited by shootist16 (edited 03-28-2001).]
Misque,
Thanks for the great review. I too think the CRKT C/K folder is a formidable knife. My first impression upon seeing & hefting one was much like yours. The only reason I decided on my M-16-04 for my first CRKT knife was because of the AUS-6 steel on the C/K folder.
After reading your review, I think I'll have to go buy one, after all. I mean it! You reminded me about the enthusiasm I felt for this knife when I first saw it. Thanks.
Jeff/1911.
Misque,
One more thing...which blade style did you choose? Plain edge or partially serrated?
I am interested in whether you know if CRKT grinds the partially serrated style blades for these knives with a chisel (only-one- side-ground edge) or not. It turns out they do on the M-16 series. The plain edged versions have a conventional two sided grind.
Thanks, Jeff/1911.
Misque -- welcome to the CRKT KFF club! Thanks for nice review, also.
I have trouble some days deciding whether to carry m KFF or my M16-14. The KFF feels so good in the hand. But, the flipper means can open the 16-14 so much quicker.
I'm a sweaty guy.
Hate to admit it, but that's the case. Also, don't use a knife too often, except for fruit and boxes. Don't use my carry knives for the fruit, so don't have to clean so often. My M16 blade looks like hell. Little stains, maybe pits, all over it. My KFF, which I've had less time, and carried a lot less, nevertheless looks like the day I got it. Also carry a couple other CRKTs with AUS6. Nary a single problem with any corrosion.
For me, the stainless factor of AUS6 outweigh any need to sharpen more frequently. Haven't sharpened any of them.
Asi es la vida
Bugs
Great review misque! I have a Crawford KFF and love it. I also have the CRK&T version and love it also! The thing that gets me is how closely CRK&T was able to match the real thing. There is not a whole lot of difference in the two, other than the obvious of course.
Art Sigmon
"I can do all things through Christ who strengthens me"
Php. 4:13
"For the word of God is living and powerful, and sharper than any two-edged sword"
Heb. 4:12
