CS Tomahawks misaligned? unsymmetrical?
Has anyone ordered CS tomahawks from knifecenter and checked to see there symmetry? and alignment?, i've ordered 2 hawks a riflemans hawk and a pipe hawk from knifecenter, months apart, the riflemans hawk was uneven, and now the pipe hawks blade looks slightly slanted has anyone gotten perfect hawks or is this regular quality to come from cold steel products, or just knifecenters handling?!?:confused:
It's probably the handle,if you look at it from the top,it may be lop-sided from when it was turned,i have to sand every handle i buy to fit the head for this reason,50 at a time and no 2 are alike
my CS plainsman hawk bought in the early 90's was dead on perfect. My frontier hawk bought much later was really bad. The bit was canted from the eye by several degrees giving it a sloppy look.
My Vec hawk with the trailhawk head is decent but it too is a little skewed. Vec puts them on his handle to remedy it though with what looks like good hand fitting.
^He nailed it, alot of times the teardrop shape doesn't perfectly fit the eye. The grinds were slightly imperfect on mine, nothing on a macro level though-I took a file and a stone to the edge and now it's good to go.
It's fairly common for CS hawks to have the bit canted in relation to the eye.
I think Vec orders heads in bulk and sends the ones back that don't meet his standards. Even there, I can see a slight cant to the head that he made up for when he made the haft.
That's been my experience too. I bought a CS Rifleman's Hawk in early 1994 and it was perfect. Years later I bought a CS Battle Axe and the head was so warped it looked like it was made by circus monkeys on angel dust.
I took a chance on CS about a year ago and bought one of their War Hammers and it's perfect.
Currently I have a CS Norse Hawk I am going to mod up. The head is canted very slightly back, maybe a couple millimeters or so. I can fix that by slightly modifying the handle though.;)
I got one of the Rifleman's hawks from Knifecenter nearly a decade ago. Didn't have an edge to speak of, and crooked as you mentioned. I was so disgusted that I threw it in the garage and I haven't looked at it since.
I ordered some hawks from cold steel's special projects about 15 years ago. i got everything i ordered but the Rifleman's hawk, it was back ordered do to Q C problems. slant or twist in the blade. I kept calling back and checking in. they got another shipment in, they were crooked too. They kept asking if I wanted to cancel, i just kept my order in. anyhow it took 9 or 10 months th finally get a straight hawk off the boat from Tiawon. I don't know what happens to C S's 2nds or rejects but they have had some troubles for a long time.
Pat
I have had 6 Trail hawks all pretty much perfect except one had a lot of excess steel in the eye. I got a rifleman that really sucked, the eye was way off and the casting was rough. I kinda hate the rifleman anyway, too heavy for a little guy like me ;-).
Best regards
Robin
Best regards
Robin
"bout to heavy for a big guy like me sometimes. :p looks awesome, hits like a truck, but dang after awhile... seems like s ton.
here is our experience, with Cold Steel in the last three years or so, handling hundreds of hawks. - take it for what it is worth to you.
we used to get the Cold Steel hawks of various makes in bulk and send back the ones that were imperfect. Lynn Thompson and Cold Steel were, and remain, great about that practice.
- for a while there, we had a lot of perfect heads - then late in 2007 (i think it was) they became markedly distorted. - the heat treat was still superb IMHO though, so after about a year of picking through the 10% that were perfect, we decided a new tack, and set the heads on our handles aligning to the bit as much as was possible, instead of the eye.
by that time in the handle development, it didn't really matter to us if the heads were slightly canted, as long as the heads were within pretty stringent parameters, and we had the capabiliy to put custom heads on our handles long before then anyhow; so we were covered - we just did more custom head work at that time.
as things like this turn out, we learned that sometimes there was actually an advantage to a bit that was slightly canted - YMMV.
additionally,
in their defense, Cold Steel heads are actually warped consistently - and the top is usually actually aligned to the eye's COM more often than not, with just the beard canting down to the right. - this is readily observable by taking the head off the stock handle and laying it upside down on a flat surface, then looking with the eye lined up to the head's top surface and top part of the bit (this is the sweet spot on a hawk bit, when this part of the bit leads, as on the Trail Hawk). - we have a few options as hawkers at that point;
1) if keeping to wooden handles, re-shape the haft so that the eye is averaged with the axis of the haft, as brother 'forge suggested.
2) mate a permanent handle to the head - this is what we do.
sometimes folks say that our hawk heads are off center - that is usually based on judging the strike point of the bit incorrectly - on a Trail Hawk with a canted bit that isn't cupped, for instance, i usually align the part of the bit at the top, which is where the Trail Hawk strikes 95% of the time, so the beard is pretty immaterial IMHO.
when the bits are cupped slightly (these are actually my favorites, for my own hawks), and they pass inspection, i "average" the cup in the bit - a lot of times these heads are ugly as sin, but tests show that they are the best performers - they must be like one of those twisty wood wedges or something, is all i can figure, and they work just as well quartering moose - we've done it. - so let's be careful of what we wish for. - let me caveat that last comment a tetch with the observation that these are very-small-bit'd hawks - it would probably be markedly less favorable to have a cupped bit (within parameters, again) on an axe or hatchet with a larger edge surface, like a norse or big Collins Axe, but in tests i haven't been able to tell the difference.
....so sometimes Reality trounces on our theories; as a prototyper i get kicked in the butt and poked in the eye almost daily, due to that phenomenon.
i've had just as much luck, if not more, with a cupped surplus Swedish Army Axe that was way off center, as i have a much-more-expensive GB Forest Axe of similar build, which was very-well centered. - folks can talk all about perfect alignment and how things are hung, but when you, the scientists, put your ankles, knees, hips, multi-jointed spine, shoulders, elbows and wrists, all bent, into the equation, i find it hard to believe that there isn't a little leeway in what is allowed in how the bit is aligned to the haft; particularly when that is a very small bit, such as on a proper hawk. - in fact, i think there is probably an advantage to a warped bit - that is definitely suggested by what i have seen in hawks, at least as i use mine.
you decide.
the practical fact is, if you want a straight bit, more power to you, but anecdotally; i have seen more straight bits chip than i have seen non-straight ones have any sort of issue. - probably because of the stresses in the straight bit, when it is mechanically straightened. - plus other production factors, including quenchants and other esoteric stuff....
we don't expect everyone to agree with us, that's another reason we have the Unconditional Happiness Guarantee. - folks risk nothing that way.
on a side note - we have made strides to make perfectly straight heads - these are all machined though - the ECO Hawk, the Fast Axe 2, and the Daisy Cutter are all examples of this. - but any machiinist will tell you that there is no such thing as straight though, and i would agree with him - you get a really dead-on eye in this business after a while, and sometimes that can be more of a curse than ana advantage - everythign loks crooked to you; all i can do is go out nd test the hawk.
facts don't lie; - when wood starts blowing up to my satisfaction, that's a good hawk no matter how ugly someone thinks it is, and i back it with our guarantee.
'can't do more than that.
....so everything is really about being within limits and tolerance.
so how much can you tolerate, brethren?
to us, you don't have to tolerate anything - just send it back and we will cut you a check or correct the issue - your choice. no risk.
the humble Hawk Project is a development process - we just want better hawks - selling them is how we survive. we have only improved because of Investor feedback and out own limited experiences. - the effect is like having an army of genius consultants there for us.
i love it.
i think that's similar to how brother 'forge operates too - good on him.
Cold Steel does that consistently too IME, backing their wares.
good on them too!
just buy from a company that backs their product, and don't worry about it.
if you want something that is perfect in every way, be prepared to pay for it - and don't use it, because then it will not be perfect for long.
that's my advice. :cool::thumbup:
HTH.
vec
