I spend the majority of my time in Manhattan - I can only get to my workshop upstate a few times a month - but this doesnt stop me from making kydes and making it on the CHEAP!
My supplies:
kitchen oven
die set from knifekits
2 pieces of molding foam from knifekits
rivets from knifekits (1/4")
hammer
heatgun (I used a candle with great results before I bought the gun)
standard power drill w 1/4" bit (bought bit from knifekits)
tin snips
knife
that is all you need!
I heat up a sheet of kydex in the oven (335* until floppy), take it out, put my blade between the kydex, then put it in between foam, put in on the tile floor put a coffee-table book on top and sit on it for 5 minute - this is my press
When it is still a bit warm, I trim the edges and get a nice shape with tin snips.
I wait for sheath to cool and harden.
I then space the holes with a teklok, drill holes and then set the rivets using the my hand die setter setup - I use a small block of wood to hold one die, then just hammer it by hand - simple and effective and cheap.
I use the heat gun to get a good fit after all is said and done and adjust tension. I used to use a candle and this worked fine on smaller sheaths, but once you start making 4"+ the heatgun really speeds up the process.
I trim any sharp edges with my knife - no saw or sandpaper.
Again, I do all of this in an apartment in manhattan with no heavy equipment - it is easily doable.
I just made a sheath last night for my new swamp rat M9 in about 35 minutes start to finish (see pics) - no the edges are not totally clean (if I was a perfectionist, some sanding would make it perfect), but it is a f'ing awesome sheath, fits like a glove, and literally cost me a few bucks...
I simply could not justfy paying $50+ a pop for kydex anymore so I do all my own and, except for the edges, it is just as good. I've literally saved over a grand by making my own. I can even do drop-leg belt loops :thumbup:
PM me with any questions.
Here are some pics for you:
all the tools I use (minus the coffe-table book and oven):
My homemade die press
Literally just finished this last night - I think it turned out AWESOME:
Since this is the ESEE forum
Have fun!
