Double Edged Safety Razors
Figured this was worth a post. After years of having Razor Burn practically every time I shaved, I switched back and forth between Electric Razors (self-cleaning Braun $180 one), and the Mach 3 Turbon and Gillette Fusion.
I finally picked up a Safety Razor off Ebay, got the Parker 90-R, and some double edged Razor blades to try.
Suffice to say, I did quite a bit of reading on technique before attempting this feat, and I have to say, that after my first shave, I had no noticeable red bumps within the first 30 minutes of shaving (normally It's noticeable within 15-20 minutes). The shave was as close as the Gillette Fusion for me, when I felt my shave on the down stroke, but on the upstroke it wasn't quite as smooth (a little stubbly). I've read that it takes about a week before you get good at this new shaving, and get comfortable enough to do the double lather (if need be).
I figured I'd share this info with others, as I was practically at the point where I'd let myself grow a beard 2x a week, so the Razor burn would heal, and it was driving me crazy, as the persistent 5 O'clock shadow was not helping my professional duties, but rather made me look lazy.
I wanted to note, that there are still the same trouble spots, that I encountered when using the Gillette Fusion and Mach3, mainly right at my cheekbone, and a few spots on my neck. These were easily remedied by using a little left over lather and going over the spots once again.
All in All, a fantastic shave that I wanted to reiterate, as well as encourage others with Razor Burn problems to consider it.
warden41272,
I've been wanting to build up to that, but I'm even a little leary of letting the barber do it.
There's nothing to be afraid of. Truly. I taught myself, then refined my technique using info I found in several locations. Done properly, there's not a DE, Mach 3, or 27-bladed monstrosity that can touch the shave you'll get from a properly honed straight razor. It's not that dangerous, either. Sure, you're probably going to nick yourself a few times, but the learning curve is quick. Straightrazorplace.com has tons of info for the guy just starting out, as well as experienced shavers. Str8 shaving was once very common, but a lot of that knowledge has been lost, and is just now being rediscovered. SRP is a great resource. It, like anywhere else, has people overly enamoured of their own reputations, and over-proud of their accomplishments, but for the most part, it's an extremely friendly group, and the information is second to none. B.S. gets called pretty quickly, so it's easier to get good info. Check it out. There are a lot of DE shavers there, too, so you won't feel left out.
Thanks, I'll take a look at it.
I'm still adjusting to the DE I picked up, and have had a little bit of trouble getting it really smooth on the hand stroke South to North on my neck.... its almost like the stubble is only present in that direction. I assume that I'll just have to do a 2nd lather and touch up going South-North to correct this.
I agree with the learning curve with this style of shaving. It has only really taken me 5 shaves total to get comfortable, and to minimize nicks.
