- Jun 3, 2019
Interesting seeing the different construction techniques. Here in mn th footings need to be something like 4-6 feet down and the foundation blocks would not be so far above grade. Flood proofing, ad you say i guess
God i wish. It is slated to be 13 below (straight temp) here in a couple days. Sounds better there!Our frost line is barely below the surface. The code calls for 18" below grade, which is at least a foot below any possible freezing
Over the years I've poured thousands of yards of concrete in my various structures. Most of that was fiber reinforced. It is certainly a labor saver on the pour but, for me, all slabs crack. It's a fact of life. I also considered concrete "permanent." I have spent quite a bit of time in the past few years repairing concrete that I poured 30 years ago. Just a couple of weeks ago we broke up and replaced an area down by the shipping barn that took 10 yards. We also spent a bunch of man hours cutting grooves in greenhouse walks that were originally broom finish. Over 25 years, human foot traffic wore that broom texture away to the point that the walks were dangerously slick. If I were doing a shop I would let the concrete cure and then do one of the high grade epoxy garage floor finishes. Maybe you have that as a plan already. I did stained concrete in my personal home ten years ago and that is holding up pretty well.Foundation filled and packed. J-bolts in place. Concrete trucks arrive this morning at 7AM to pour the slab floor. They are using fiber reinforced concrete. It is as strong as re-bar reinforced concrete (stronger according to the mason). Photos later today.
Agreed there ! Construction methods differ.
I not seen a CMU foundation on anything, even ‘agri or accessory buildings newer than 50-60 years.
Even leaving the sod in place is strange, that would be scraped away whilst the excavator was still on site.
Yes, I think there should be no organic material under the concrete as it will rot and gass off.
Never seen any that long, must be because you are right on the ocean / hurricane proof ? The ones we use around here are maybe 8"Tomorrow they will come and put the J-bolts in the foundation walls. These are 36" long threaded rod with a 90° angle on the end.
