- Aug 27, 2004
Next up is an older Waveless Commander sent to me from Greece to be converted to a tank built frame lock. This one has developed some blade play and the lock slides toward closing with just spine pressure so the owner decided he wanted it upgraded to a chunky frame lock that will be both stronger and more reliable for him. At his request the non lock side will remain G10.
These models are always a bit of a redesign also since the lock is cut out with a laser. Unlike some others though this one can still be pulled off but the handle will change slightly. You can see from this shot here scanning the inside view how the lock cut is U shaped toward the pivot and also the big sweep the lock cut takes to loop it around the thumb access. Neither of these things can be duplicated with a mill cut off disc so I will have to bring the area for depressing the lock up just a bit to make up for the straight line loop line difference when I fix that. I will also have to cut my short cut without the option of the U cut so the handle will change there also.
Long story short, its very similar to the view of the CQC8 on the insides and a couple of other models I have converted to date. Stay tuned I will be tackling this one and its followed up by a CQC13 after that. Both of which have been here for a good while already. One, this one, from Greece, and the 13 from Italy. Go figure I'm international!
STR
STR
