Haze I guess we had a problem in communication here with that last post you made. Never saw it until today. My apologies. As you can see from the scans I already tapped it for factory the way I always do so the folder can go back together as it came with no permanent mods done to the non lock side, or the folder. I do that whenever possible with the exception of the lefty conversions where it can't be avoided.
I made a lot of headway on your Persian. My problem is that I've already drilled and threaded the pocket clip holes for the factory position. You just filled out the form with all the areas I had but with no notes to remind me that the clip was to be slightly moved and since thats all I have when I get to working and didn't see that I did it as usual. I do apologize.
I'll tell you what I can do though if you can live with this other than my having to remake the whole lock, I can make a clip from scratch in a standard style like the Emerson but curve it to fit as you like. It will look much the same as the factory clip for mounting area at the screws with the same shape, just curved to fit the folder body and perhaps a bump longer to flow with the elegant elongated body of this folder. You call there. Since this is my bad I won't add any $ for the clip.
Anyway here is a scan of where I left off today. Its rough but the whole knife is done and goes together now I clean it up and its basically a frame lock other than placement of the detent and making my lock cuts to spring the lock.
Get back to me I'll wait to hear from you before moving further on it.
Thanks
STR
