J
If you make a cutting tool out of copper
1/8" round copper wire and sharpen the end,
like a chisel maybe just a little less angle,
and put it in a file handle you can use it to
cut away solder with out marring the steel,
This works well, you can make any size or shape
to fit your needs, for a wider tool I use a
piece of 1/4" copper tubing and flatten the end then
sharpen it.
I'll also use my air gun to blow away
some extra solder before it solidifies, being careful
not to blow it out of the joint.
Wear your safety glasses.
you can get the copper wire from any electrician,
it's entrance grounding wire.
