Some one asked about a dovetail jig. This one is simply the corner of a 2"x4" cut off at an approximately 45 degree angle. I took some soft steel and countersunk some screw to attach the flat stock. This gave me something to clamp it to the tool rest and a smooth face to slide the bolster or scales on. In the bottom picture you can see (barely) a set of dovetail bolsters clamped onto a blank to see how they line up. I found I had to hand file a bit to square it up after using the grinder jig as the corners tended to round down leaving a high center. I'm guessing the belt tends to wrap around the bolster or scale material.
I would like a variable jig but just don't have the ambition to put one together.
On my Frink grinder, I used threaded bar and some nuts to lower the tool rest for the jig to use on the flat planten. It seems to work and cost a total of $2.75 which is entirely too cheap. I've started to nag Rob to come up with something like it and charge me a great deal more so I'll feel better about it.
