FYI -- The Blade Geometry FAQ, and more article links
at knifeart.com
Knife Information Center
http://store.yahoo.com/knifeart/knifearticles.html
Khukuri mentioned briefly in:
http://store.yahoo.com/knifeart/bladgeomfaqb.html
The Blade Geometry FAQ by Joe Talmadge
Contents:
I. Introduction to the Blade Geometry FAQ
II. Blade Characteristics - The Belly - The Re-Curved Belly - Bellies and Angles - The Point - Blade Thickness - Edge Thickness - The Primary-Bevel Edge
III. Blade Grinds - The Hollow Grind - The Chisel Grind - The Sabre Grind - The Flat Grind - The Convex Grind - The Dual-Ground Reinforced Tanto
IV. Blade Shapes, and What They're Good For - The Clip Point - The Drop Point - The Tanto * Americanized Tanto * Chisel-Ground Tanto - The Sheepsfoot - The Dagger - The Spear Point - The Trailing Point
V. Steel and Blade Geometry
VI. Putting It All Together - Two Combat/Utility Knives - The Camp Knife - Three Folders - A Hunter (Classic Loveless and A.G.R. Deerhunter) - A Custom-Made Folder
