Gerber tool adapter fits on Leatherman Juice
I was trying to find a tool adapter that would fit the juice, so i could use all my 1/4 hex bits, and found the gerber philips adapter slid on nicely with just a LITTLE play, but seemed like it would perform well. The magnet inside the adapter held it firmly in place. I forget which juice i tried this on, just remember it was blue, but the screwdriver is probably??? the same on all of them.
I also tried this on the swisstool, but it didn't slide on all the way because the driver gets wider partway back from the head, and the adapter hit on this, without a snug grip or the magnet holding it on. You could probably remedy this with a dremel.
Something else to think about is Dewalt makes drill bits with 1/4 hex shafts, if you ever wanted to turn your multi tool into a drill. To get an idea of how this would work i grabbed a drill bit with some lock grip plyers and practiced on some plywood, it put a hole in it pretty quickly without much effort.
Any ideas?
Brad Davis
