- Dec 3, 2010
hey all your guys in BF, it's my first thread in BF, i'm from china,
there is also a lot of knife makers in china,but they always not good at english(my english is so-so as well
),so there is hard to find the knife and design from china. I hate the copy ,and I will share some knifes with your guys
this knife is made by carson-tech,who is stated in the south of china,he is a talented knife designer and maker,all his knife is modern and tactical,hope you guys will like it
The Granite is designed for a daily user,drop point and big flat grinded balde is more useful.The one piece handle is made of 6Al4VTi alloy,which is whole heat treat ,more stronger and wear-resisting!The integral bar lock has a reinforced hardened cpm154 stainless steel replaceable section - it really gives a strong lock,This steel section is replaceable after many years of use, bringing the lock back into it's original locking position. Dual thumb studs and flipper for easy right or left hand operation. Flipper serves as an index finger guard in the open position.Filed thumb rest on the handle as stop pin,a extremely strong edc!
Specifications of Granite:
Large Granite
verlength:214mm, blade length::92mm ,thickness:4mm
Small Granite
verlength:183mm, blade length::79mm ,thickness:3.5mm
Balde materials:cpm 154,ats 34,damascus hardness:hrc 61+/-1 (Each blade has a hardness-test point)
6Al4VTi one piece handle,whole heat treated ,the bottom of shrapnel and the lock bar is double heat treat
Replaceable bar lock build with cpm154 stainless steel hardened toHRC 48+/-1
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Large Granite
Small Granite
