handplane blade are chipping. Please and thank you.
Perhaps this is a little off topic, so I hope you don't mind and can help me with this. I suspect I know the answer but need a little feedback.
I made my own handplane blades from A2 tool steel, hardened to Rc 59 and 61 with a 25 degree bevel. The bevel and the blade (flat) was ground on a grinder from a machine shop (this may be my problem). When I plane an oak board I get minute chipping along the cutting surface almost immediately. Is my grinder creating too much heat and hardening/softening the cutting edge? Should I slow down the feed rate? Do I have to avoid the grinder? What grinding speed and wheel do you recommend?
What are your recommendations. Thank you.
Vlad
Were the blades tempered or drawn back after heat treat? If not they are to brittle and are prone to chip on the edge as you are describing.
Mike
I also got some A2 for plane irons but I haven't made any yet. I would appreciate hearing more about what you've learned. How did you harden and temper the blade? I wonder about the standard instructions to soak A2 at high temp. for several hours. Isn't this bad for edge tools?
Are you honing the blades after you grind them? It sounds like you have the right hardness, A2 is pretty tough. I would try taking a hard arkansas stone or a ceramic stone and honing the the edge at a 30 degree angle after you grind it. That will smooth out the edge and eliminate any microscopic teeth that are left after grinding.They can make a blade seem sharp, but break off as soon as you start cutting. Honing at a steeper angle gives you a very fine secondary bevel that will make the edge stronger without hurting its cutting ability.
I may not be the sharpest knife in the drawer... but I've got the sharpest knife in the room.
Thanks to all.
I hope I can answer some of your questions. The blades were professionally heat treated. A2 is not soaked in oil it is air cooled, if I'm not mistaken. I put on a secondary bevel of 27 degrees. I'll try a secondary bevel of 30 degrees and report back tomorrow. These blades were manufactured by my brother who is doing me a favour. If you have any further questions please email me directly.
Regards,
Vlad (Canada)
