handplane blades are chipping?
Perhaps this is a little off topic for all you knife makers, so I hope you don't mind and can help me with this. I suspect I know the answer but need a little feedback.
I made my own handplane blades from A2 tool steel, hardened to Rc 59 and 61 with a 25 degree bevel. The bevel and the blade (flat) was ground on a grinder from a machine shop (this may be my problem). When I plane an oak board I get minute chipping along the cutting surface almost immediately. Is my grinder creating too much heat and hardening/softening the cutting edge? Should I slow down the feed rate? Do I have to avoid the grinder? What grinding speed and wheel do you recommend?
What are your recommendations. Thank you.
Vlad
You might want to pop over to Shop Talk in the General Discussion forums and post the same question (if you haven't already). More likely to get an answer there.
The most affectionate creature in the world is a wet dog. - Ambrose Bierce
Most dog owners are at length able to teach themselves to obey their dog. - Robert Morley
iktomi
