Hardwood Pins
I've got some nice cocobolo and rosewood scales to use for handles. My idea of the day is to use a hardwood dowel for the pin material. The only hardwood dowels I've seen are made from oak, birch, and walnut. Should a wood pin be stabilized just like handle material?
I would prefer to use ebony, rosewood, or cocobolo wooden dowels for these pins and not worry about stabilization. Does anyone know a good source for these?
Thanks in advance,
Allan
Use regular pins, but countersink the holes for 1/4 inch dowels & use short pins that stop at the countersink.
Get a 1/4 inch plug cutter from a woodworking store. Cut round plugs from the handle material stock. Line up the grain of the plug with the handle & glue in.
John Ownby
http://www.johnownby.com
So *that's* how they do hidden pins. That's one of those things I've been meaning to ask but keep forgetting, so thanks, John.
I was going to suggest turning your own pins from your stock, Allan. You could use a lathe, possibly chuck some stock into your drill press and rig a rest and go to town.
Dave
I agree that hidden pins made of brass or stainless would workm better for you. But a good source for exotic woods is www.woodcraft.com . I'm fairly sure that I've seen exotic wood in dowel rods in there. And they have plug cutters too
I may not be the sharpest knife in the drawer... but I've got the sharpest knife in the room.
If you're gonna cut plugs, they need to fit tightly. Lee Valley tools has a cutter that cuts a tapered plug so it will always fit perfectly. Leevalley.com
Another alternative is to turn your own pins on a small lathe from whatever stock you wish. That way the grain will be running the proper direction, too.
