- Aug 27, 2004
Two more in my spurt of knife making just up. I actually have a third one I did as well but its needing some adjustment on the contact before it will be ready so I just stuck with the two completed. Once more these are the same pattern with various blade shapes I've come up with to fit into the same handle shape. I tend to like more traditional straight forward designs as opposed to all the fancy smancy curves and grip grooves. To me a straight forward more "Puukko" type handle is more versatile in a multitude of grips making the knife about as easy to use flipped on its side as it is upside down or right side up.
Anyway, this handle appealed to me years ago when I saw a drawing my good friend Dirk Potgieter had done and at first the model I made was similar to the one he did but as things progressed little by little I eventually modified it so much that it is hard to tell its the same general pattern anymore. Hence the He-Man name sake.
These again both weigh close to 3 ounces each. They are 4 and 1/4" long closed, with slightly over 3 " blade lengths open. The pics say it all as they both stand on some logs out back together. I did both of these once again in the same .095 thickness titanium slab handles and neither one of these has a lock cut in the lock. The locks are solid just like they come and they are some stout locks. Not for everyone I know but for someone wanting a totally unique lock unlike any you'll fine anywhere else well, you are looking at it.
I'm starting to see a pattern here with hunters. It appears that they like carrying deep without pocket clips. You probably noticed that this hunter model, just like the last does not have a clip. The hawkbill however, did get one of my custom made ti low rider clips on it for right hand tip up carry.
The Hawkbill model shown here is available currently. $250 pay pal preferred contact me if interested. Thanks
Oh and more pics in my blog if interested.
STR
STR
