J.
I also welcome you to the forum. As a new member, you have not yet had the chance to preview all the great ideas and even some "miracle" fixes, the guys and gals have shared...
If you want to try and make some knives from files without re-hardening and do not want your handles to fall off, try "spot annealing..."
This I learned about from the message traffic on the forum, I do not remember who to credit...
This came out when one of the members forgot to drill the holes for the pins for the handle. The suggestion was to chuck a nail--16p (head and point cut off) into a drill press and then "try to drill a hole" in the tang at each location you want a hole for the pins.
Of course, you can't drill a hole with the dull nail, but what you are doing is spinning the nail under pressure and the resultant heat from the friction will anneal the steel enough to come back and really drill a hole with a real drill bit.
I tied it and it really worked. It might take you several times to get the steel soft enough, but it will happen. Just remember, the steel needs to cool slowly.
One more bit of advice, be sure to cover up the "biggo" hole in the drill press table or the sustained pressure and heat might warp the handle.
Good Luck...
Bruce Jensky
PS: Try out the search routine and you will find lots of problems already solved. It might even save you the embarrasment of asking how to get a broken tap out...
