Hello,Been a long time since I have been here.I have the same question as I did along time ago.First a little background.
I am making diggers to use metal detecting.The only ones you can buy are not near long enough and are made from soft stainless and dull quick(like the short one pictured).The first one I made(pictured) I used 5160 spring steel and stock removal.I never got it too hot and when I was done I could take all my weight(alot of it)and bend it down and it would flex back.I made this for a friend.He posted it on a detecting board and now I have several people wanting me to make them diggers.The first one I left with the curve(helpful to scoop dirt out of the hole)but it was a pain to shape because I couldn't lay it flat on my 6x48,so most of the shaping was done by hand.Well to quicken it up some I straightened some stock in the forge and have them shaped and I just took a piece of railroad track and had a piece of 2inch and a piece of 1 1/2 inch solid rod welded on it so I can shape the digger on them like a garden trowel,cupped,instead of the curve,for dirt removal.Sorry for being so long winded,but I wanted you all to know exactly what I am trying to do and the reason for the question,so now,the question.
When it is all shaped and done,how should I go about heat treating it and tempering?It has to be hard enough that it will not bend and stay bent,but soft enough that it will not snap.Spring seel is how it should be,but my dad says once it has been in the forge,you can not bring the spring back.At least he don't know how,anyway.These will be used with the cutting edge cutting a plug in the ground then the plug will be pried out with the side/front of the digger.Sometimes in concrete hard dirt.The serrations for cutting roots.I am going to be getting way more for making them than you can buy the factory made digger,so I want to make sure I do it right.I want it to be something that will last them for years with proper care.Thanks,Ric
