Kodiak PA
- Dec 3, 1998
I have been wanting to report my findings on this knife for a while. All to often we see the reviews on the mechanics of a new folder but we don't really see too many follow up reviews after owning a knife for a while. I often smirk a bit when I see a knife review and no one has cut anything with it. I admit, I have done that myself.
I have had my Al Mar SERE 2000 for over 6 months...these are my following observations and grades.
Blade: I like the VG-10. It holds a keen edge and is easy to resharpen. Is readily stainless so that isn't much of a concern. I like the thin bevel and the point is very strong. The semi-mirrored finished is attractive and if you wanted to dull the finish a bit you could use a Scothch pad and some Metal-Glo. The spine of the blade is way too sharp for hard work. I had to use my dremmel and some 250 grit sand paper to smooth it out a bit. The blade rides smack in the center no matter what I do to try to screw it up on disassembly and reassembly. Grade: B
Linerlock: This was a big disappointment. The liner originally failed the spin-whack test. I disassembled the knife and adjusted the liner against the tang a bit and it was better. With hard work the liner starts to ride over to the right. I suppose this makes the liner a bit stronger with hard work applications but with light chopping on mahogony the liner froze all the way to the right and I had to take a screw driver and tap it free. What good is the beefy liner liners if you can't trust the lock? Grade: F
Thumb stud: Though this knife has a dual thumb stud I find it way too sharp to open comfortably. I again had to take my dremmel and sand it down a bit to make it more comfy. The thumb studs on the S2K have these mutliple layers and taper towards the top of the stud. Though I like it better now give me that Spydie-hole any day. Grade: F
Scales: The G-10 handles are comfortable and thick. There is a right finger index groove for comfort and the pocket clip does not get into the way. Combine the thick liners and thick G-10 scales and you have yourself a very comfortable knife to hold. The knife also has an integral guard on the scales which prevents hand slippage. It is grooved on the top for a comfortable thumb placement. One thing someone may notice when you look at the S2K is that the handle looks disproportionally larger than the blade and it is. Grade: A
Pocket clip: The clip is either right or left carry, tip up and is mounted on the end of the handle for a very low riding discrete carry knife. Because of the poor thumb studs during a fast drawer out of the pocket the studs can catch and open the knife on you when you don't expect it. Now if you wanted this to happen like the Wave feature on an Emerson knife that is one thing but on this knife it may be a safety consideration. The clip is attractive but its high grit finish may turn people off. Grade: C
Overall observation: I like this knife but I do not trust this knife. I like the steel, the toughness of the point but hate the spine. $120 knives should not have to be adjusted and dremmeled. The beefy handle does inspire confidence and even though I think spine whacking is overrated this still may be a concern to some people. I do have confidence in the knife now but I had to take it apart to feel this way. I had to do this on a Spyderco Military once too, so the Al Mar is not alone in this venue. The cutting ability of the blade makes it nice to use and its ability to shave after cutting wood and shaving mahogony was nice. I like the deep riding clip but do not like the knife catching on the layered thumb studs and opening when I least expect it.
Overall grade ont he S2k: C
I welcome your opinion on this review.
Sincerely,
~Greg Mete~
Kodiak Alaska
Buck Collectors Club-Lifetime Member
JKM-Chai
KnifeKnutt@aol.com
[This message has been edited by Kodiak PA (edited 02-18-2001).]
Sincerely,
~Greg Mete~
Kodiak Alaska
JKM-Chai
KnifeKnutt@aol.com
