How do I cut "stuff"?
What's the best technique to cut branches, limbs or other semi-rigid objects?
Using a 15" khuk, what are the best wrist positions? More shoulder or elbow? etc?
Don't forget I'm just a little Saudi :D so I won't be able to put a huge amount of weight into the swings.
Bruiser -
Use a "comfortable" swing, and practice a wrist snap at the end, just before contact. Start with a length of 1" branch, over a log, sawhorse, stump (annoying neighbor), whatever. Don't go for power. Work on timing the swing down onto the branch, and snapping the wrist as you come into contact. The muscles that are not used to these motions will strengthen as you repeat. Power will come as they strengthen, and as it all comes together as a "one motion" act, you will find it easier and easier to apply it to other direcional cuts. As you progress, you may find yourself pulling the blade back a bit, along the line of your forearm toward your elbow. Add this to the swing/wrist snap, and you have the beginnings of a draw cut.
I can cut 1 1/2" branches with a 21" Chitlangi without undue forceful use of muscles - I don't have forceful muscles to use any more. This cut can be used as an overhand chop, a lateral cut or a 45° "uppercut" from left hip to a target in front of your right shoulder (or reverse for southpaws). I don't know if this is proper terminology or technique, but it is what the Khuks taught me, and I trust them :D There is a great deal of "power" (read mechanical advantage, leverage) built into the crooked blade. When your swing is quick and smooth and your timing is natural on the snap and pull, more power will come. Eventually, when your yard is bare, and all your neighbors have electrified their fences, you will be ready for saplings and small trees. Move to a National Forest (remove your liscense plates and wear a mask) and go on to greater things. :rolleyes:
Don't have any technique advice to add to Wal's, BUT I would second his idea of chopping over a log or stump. When you are not used to these knives and how much force/momentum they generate, it is all to easy to chop through the target and find the blade sailing onward toward parts of you want to keep attached/unscathed!
I almost learned this the really hard way when I got my first khuk (20" AK). Due to dumb luck (or God really does protect drunks and fools--I was in both categories at the time--now only the second:D) the khuk missed chopping into my shin only because a sapling deflected it on the downswing. Interesting that the big AK sailed through a 1.5" branch like it wasn't there and was redirected away from me by a 1/4-1/2" one:)
BTW, are you really a Saudi or just kidding?
"Don't forget I'm just a little Saudi "
Does anyone else have the sneaking suspicion that BruiseLeee is probably as tough as nails and maybe the last person you'd ever want to corner??? -Oh and Bruise, I DO remember your avatar before you changed it. ;)
Now that you mention it....hmmmm.
Tsimi is always portraying himself as a bent, frail old man. Instead of a martial arts teacher barely in middle age...:confused:
So to go with the opposite of Bruise's posts he is 6'6 250 lbs, and of Nordic origins??;)
The next Konvention will be interesting if everybody that posts now shows up--I'm definitely going this time. And for the record I'm 6'0 and bald, about 230. And not tough.:D
Actually my old avatar was a picture of Bruce Lee. I didn't think anyone would understand so I changed it :)
Also, I think my current avatar is a pretty accurate self portrait. The head may be a little too small though. :D
Bruise, I suggest you re-read the safety thread.
The amount of damage a khuk can do to flesh and bone is terrifying.
You don't want to change your handle to "Stumpy"!!!!
--Mike L.
Bruise, go slow, and start out with your shortest khuk, or most manageable khuk. Maybe it was the khuk talking to me, or that I had played a very little serious badminton long ago, but I caught onto the key wristsnap thing right away. Go for smooth, easy, not too fast arm swing with control and precision, then snap the wrist as described. Don't try to use a lot of force. The khuk will do the rest. And for safety's sake, make sure that the knife can't swing through back to you until you really know what's going on. So use a chopping block or something at first. Wear shoes!! Later on you can try to slowly develop a movement that resembles slow-motion cracking of a whip, from your shoulder to the wrist, then to the khuk's sweet spot which hits where your'e aiming. You will be amazed at the power. And the blade does almost all the work. Don't try this until you know you can hit the sweet spot, or you'll get a nasty jolt to your hand. It's not brute strength, but smoothly accumulating and focusing momentum with full control. Easy does it. That's why khuks are so entrancing to use. I can't pull this off with my 25" sirupati, my wrist isn't strong enough, that's more of a one-handed sledge-hammer or axe movement, which also just accumulates and delivers momentum with a minimum of effort on your part, letting the tool do the work. Three nearly effortless hits to acomplish the cut are much easier and safer than a single, out-of control, slash that takes a huge amount of effort. When cutting branches, aim within and inch or two of the trunk so the springiness won't fight against you. Slow, smooth control, beats flailing anytime, you can keep it up much longer, and you'll be certain to return home intact!! Enjoy.
All the easier to get people to "jine up" to the fellowship. Who'd be afraid of a little old guy? Everybody who knew the truth! I stick out my tongue, but from the safety of thousands of miles away.:eek: :D
I gotta be the EVIL ONE to his :barf: "Goodness" :rolleyes:
Roger,
Well, you're certainly out "marking" some territory tonight!! [ I said I'd jab both sides...]
I think you're just jealous that Paxton has produced a cartoon character for the 'researcher' and you've not one........yet????
"Roger Smith: hehehe"
...Ask and 'ye shall receive :D
HAWHAWHAW! ROTFLMAO!
I knew it wasn't going to be pretty. :p
I hope I'm not the cat, but I probably am, because I'm not bald.
Lesson: Don't Pi$$ off PAxton!:D :D
Rog,
Your'e right not pretty!
But check again, that's a nekkid cat!!!:eek:
Either way, you lose on the hair front....
Fir,
Man I get it coming and going! ROTF and all that. haha :p
Nekkid cats? I'll take Evil Genius anytime. Gotta modify my sig line.
