- Oct 26, 2011
Has anyone tried to make their Shallot a manual flipper? If so how is it?
Thanks,
-orangish ducktape
Thanks,
-orangish ducktape
It's functional. I've had mine for four years and the thin design and lightweight profile means it gets carried a lot when I run, and then sometimes into the nearest river/pool/lake once the run is over. About a year ago the torsion bar broke (action got pretty rough, too), and I kept using it. Just took a little more wrist action than usual. Two months ago I opened the thing up, and, as expected, the insides were completely covered in rust. I removed the torsion bar, took as much rust off as I could with 400 grit sandpaper, and closed it back up.
It's smoother now, though not as smooth as when I first got it - I didn't do that careful of a job getting all of the rust out. But I can open it just using the flipper; no wrist action required. Blade is still centered, lockup is still solid, and it still comes with me when I go running. Pretty solid for a $55 knife that got carried as an edc for about two years and helped dress out a few deer along the way.
So, I guess what I'm trying to say is you should be fine, though the stop pin might give you trouble on disassembly/reassembly.
Honestly, if there's anything that surprises me about the Shallot, it's that there aren't more people singing its praises.
I have a shallot don't use it much but when I was useing it the the knife got unlock almost took my finger out since then it sits in my safe.
