- Mar 5, 1999
It's monsoon in Nepal -- raining everyday with humidity at near 100%. Rigs get humidity soaked and then come to Reno where it's been near 100 degrees with maybe 15% humidity. These blems are a result of the change in climate.
Here's a perfect 18 inch, 17 ounce Kobra by the kami with no name. The only problem with this entire rig is the tear at the top of the scabbard which you can clearly see in the pix. This tear which you can cover with Kiwi shoe polish or patch saves you $30. We will deliver this very good rig to your door with full HI guarantee for $70.
Call or email if interested.
Here's another perfect 20 inch AK by the kami with no name. The rig is 10/10 with the following exceptions. There is a nickels worth of rust damage at the tip of the blade. About 10 minutes to get rid of it. And, the scabbard has shrunk -- blade cut through right at the mouth -- you can see the cut in the pix. Can be patched or sent to Terry Sisco for repair. READ THE SAFETY THREAD BEFORE YOU TAKE THE KNIFE OUT OF THE SCABBARD!
The rust and scabbard damage will save you $60. We will deliver this very fine rig to your door with full HI guarantee for $135.
Last casualty is another 18 inch, 20 ounce kobra by the kami with no name. (He's on a roll!). It's another 10/10 effort that's got about a dollars worth of rust damage at the tip which you can see in the pix. 30 minutes maybe to get rid of it. And the scabbard has pulled apart at the stitching in the back for a couple of inches but nothing shows and it is very tight due to shrinkage but a higher humidity environment may fix this. Rust and scabbard saves you $40. We will deliver this rig to your door for $60.
