Congratulations Lanny on your new acquisition and welcome to the world of custom knives. I hope all is well. We haven't spoken in a while.
Ideally, you would like the liner lock and blade to meet either mid-way on the back of the blade, or closer to the right side (since this is a left handed model) of the blade (when the blade is facing you)without the edge of the liner protruding over the edge of the blade. But, as long as the liner isn't hanging over the edge, and the lockup is tight (no vertical or horizontal shake) it should be fine. Of course the more bend in the liner, the less strength that it will have under EXTREME conditions. But, will you be using the knife in that fashion??
If it bothers you, contact Allen Elishewitz, I am sure that he would help you out with it no problem.
My experience has been that when using a liner lock, the majority of the pressure is not really put on the lock itself but on the stop pin in the cutting process. The lock itself is just one component in the knife (albeit an important one). There are other contributing factors that can cause the lock to be compromised in use. One of which is the rigidity of the handle. If too much side pressure is put on the knife during the cutting process (it is squeezed too tight), and the liner rests close to the edge of the back of the blade, the side pressure could move the liner off the edge. I personally have never seen that happen.
If the knife can be potentially used for protection which could include potential stabbing, the liner lock may be more prone to failure due to potential backward pressure. Thought that may be only in extreme use.
I have had a number of liner locks that had liner locks beyond half way, (mostly spyderco models, not customs), but with no incidence.
If you decide that you want to send it back to Allen for work, check the knife over well, especially the lockup (lateral, horizontal and vertical). If there is a problem, make sure that you are as specific as possible about it.
Send me an email or call me about it if you would like to discuss it further.
Again, this is my experience and opinion. Some may not agree.
Thanks
