Inside Waist Band Sheath
blgoode
Inside Waistband/ Conceal Sheath
This is my standard pouch sheath converted to an inside waist band sheath. I have detachable belt loop lengths to accommodate different belts. The screw that holds the belt loop also allows for a pivot movement that adds to the comfort.
This turned out well.
The belt I have on is a 1 1/4" belt. You can see that the loop will accommodate a larger belt. The slack fit allows for the sheath not too bind up when bending or shifting around in a car.
Knife is my SideKick / 6.5" overall model.
Thanks for looking.
In the last image you can see where a larger 1.5" or 1.75" belt would pull the slack in the loop down. I made a shorter loop for smaller belts.
I may just have to make one of these for myself. What about a similar system to be able to change out belt loop lengths? That would have been good in your case with your Companion Burnsy. Oh, by the way....The Sidekick rocks as an EDC fixed blade!! I'll get yours started soon enough my friend ;)
Looking good Brian! I really like the belt attachment system. With a fixed blade, you're liable to take the sheath on and off a lot just for comfort if you're not going to be using the knife, and with a standard slide-on it would get pretty annoying without a button.
Thanks Needle. Any new developments in your custome knife search? Its endless my friend :D :D
An adjustable loop system would be a great innovation Brian. No rush on my end-look after the important customers first.
Burnsey - Every Customer is an important one ;) ;)
Nothing new Brian, but I sent you an e-mail Sunday night. If you haven't recieved it, let me know.
Humm...resend it. I didnt get anything.........
