Cliff Stamp
BANNED
- Oct 5, 1998
After working with a few Japanese saws and kitchen knives I was readily impressed with the cutting ability and edge retention due to the focus of the blades. Recently I had a discussion with a traditional maker about this knife :
http://www.watanabeblade.com/english/special/echigo.htm
Which he called a machete, similar blades are also called axes, Garret Wade sells a rough version. The above handmade blade is hand forged Hitachi blue steel laminated between wrought iron. The steel is uniformly hardened to 62-65 HRC. The edge is convex, ~15 degrees.
Murray Carter also makes similar blades (his handmades are much more expensive), not a lot of feedback on such knives on the forums, or on the net in general however.
Like the kitchen knives and saws, it is likely that these machetes or axes require a different method of use to bring out the true performance than the western versions.
-Cliff
-Cliff
