The Kershaw RJ Martin designed Groove is one of the first 3 New Kershaw Flippers (link)
The first thing noticed with the knife open is pretty obvioulsy that "groovy" blade. I would guess it is really more for looks and it certainly looks very impressive - however those grooves probably work like kullens on Granton edged knives, where the lower surface area would help to lessen the possibilty of things sticking to the blade face.
Compared to the other new Kerhsaw flippers for size -
For me the most prominent difference other than that "groovy" blade is the flipper -
the Groove has a more conventional looking flipper more like a post or "trigger" - I personally prefer the rounded ones on the JYD and JYD2 - as they look less likely to catch on clothing etc.
I am so impressed with these new Kershaw (Tim Galyean designed) flippers
- they are like an "unassisted assist" - once one gets it, the knife can be opened with just the pre-loaded tension of the index finger and the knife opens fully with "authority".
The Groove is not quite as astonishing as the Kershaw JunkYard Dog II I reviewed earlier.
The trick for me is to start by pressing down on the flipper first (to pre-load finger pressure) then pull back and down - the blade then more or less flies out.
I think the reason why I can't quite get the same opening with the Groove as the JYD2 - is simply due to the blade size/weight and the amount of interia/momentum of the blade when flipped.
- but I can still get the Groove to open fully quite reliably without having to flip (or move) my wrist.
The Groove is a frame-lock -
although there is the decorative scale that covers the lock bar partially.
Unlike the JYD2 (and JYD) the Groove does have a conventional (back) stop-pin -
Markings -
Compare for size -
strangely enough the Groove kind of reminded me of the CRKT My Tighe.
All-in-all this is another great knife in the new innovative Kerhsaw (Galyean) flipper range.....
and that blade sure looks groovy.
Vincent
http://clik.to/UnknownVT2007
http://clik.to/UnknownVT2006
http://clik.to/UnknownVT2005
http://clik.to/UnknownVT2004
http://clik.to/UnknownVincent
Markings -
Compare for size -
Vincent
