Knife Lightening
I have recently received a Buck Vantage and Benchmade Vex. Both are real nice especially considering how little they cost. They are much heavier than I like and I am considering talking them down to their stainless steel liners and drilling them to reduce the weight. Are the liners hardened and will I need any special drill bits? Any advice or has some one got experience doing this type of modification? I know not to get too nuts around the liner lock as not to weaken it.
Most of the weight will be coming from the blades themselves. Drilling the liners will shave weight, but not much. In the BMX world (i bmx) we go to such lengths as to change all the bolts out to titanium to save weight. Me, i stick with the strong stuff like chromoly, but thats off topic. Go to the hardware store and change the bolts and such, drill out the liners with a few large holes and maybe even sand down the G10 a bit. Honestly, thats all i can say to save weight. But i wouldn't do that anyways. I owned a vex for a short period, its a really light knife compared to others.
Buck Vantage's only weigh 4 oz. (which is about my limit for an EDC, unless it's in a sheath) and the Vex is approx. 4.8 oz. Do you really need to cut that weight down? Just wondering . . .
Here's edited notes, on what I did a while back to one of my tacticals. This will remove a little weight, and you'll be able to tell if it's significant enough by weighing before & after.
1: If you can, weigh the knife first. (I use a kitchen scale.)
2: Take the knife apart, and using a sharpie marker, mark all the pre-existing holes.
3: I start with a small drill bit, and drill a pattern of holes all over the liner. Do not drill any holes in the locking lever, or around the area where the lever attaches to the liner.
4: Drill small holes first, then move up to a larger bit & drill larger holes, using the smaller holes as guides. Do this until you have the holes drilled to the size you want them. Don't drill the original marked holes.
5: (I do this step, as it make cleaning the knife easier) Use a countersink bit in the drill and ease the edges on the holes, on both sides of the liner. DON'T DO THIS TO THE MARKED (pre-existing) HOLES!
6: (This is optional too) Match up the liners their respective scales, and using the holes as guides, drill into the scale far enough to remove a little material. Be careful not to drill all the way through. Use fine emery cloth to smooth out the scale holes.
7: Lube & re-assemble. For cleaning, I just use an old .25 cal. nylon bore brush; since all the holes line up, and the edges are smooth, the bore brush works really well.
8: If pivots loosening up is a problem, I use a small drop of clear nail polish in the pivot. It's semi-permanent, but can be dis-assembled later if needed.
There it is. For a knife 4 oz. or under, it may be a lot of work. Anything over 4 oz., like that Vex, might be worth doing it to. Good luck, and let us know how it goes.
thx - cpr
You can get special bits for SS but even with these the trick is to drill slow. Once you hear a squeal the bit is fkuced
