Hey Fubar....
Forming synthetics is not difficault...
Somewhat difficault to get just right though...
The basic process is quite simple really...
I use blue sleeping pad foam. Other expensive foams can be used,,but have to be ordered and thats a pain in the A$$.
Stick with as many materials as you can find local...
I also use 2 layers on each side of the mold.
Roughly 1 inch on each mold side.
This with give you what I call a 3D sheath..A 2D sheath is flat on one side and molded on the other..
To obtain this you use foam on the top and a flat piece on the bottom.
The smoother your flat piece is the better or nicer of a finish you will have..
The same goes for the top mold..Any scars, nicks,dents or assorted damage to the faom will leave a mark on the finished product.
Avoid that.
When my molds start to show damage from heat cracks,or Major indentations, they get rotated into folder duty doing neck rigs. After that the garbage.
I run three custom presses and 6-8 different molds. I cycle as needed.
Onto the press...
You want alot of pressure from you press..
At least 300+ lbs on an 8X8 mold.
This type of pressure **can't** be achieved by standing on your molds..
Quick clamps also won't give you this pressure...
Pipe or C-clamps will...
The absolute best is Straight downward pressure, or lateral pressure from say a large vise of some type...
Doesn't matter what is producing the pressure as long as it is even and spread out across the mold.
Standing and rocking is about the worst thing you can do. The knife will slip and move around giving you uneven pressing and a Weak definition on the blade.
You are seeking Crisp ,Clean lines....
If you have any further questions, Please feel free to e-mail me privately..
Hope this helps..
ttyle
Eric....
On/Scene Tactical
Leading The Way In Quality Synthetic Sheathing
