Lamey Camp Bowie Review (long)
Matt Lamey Camp Bowie
Review by Kevin Pensinger
May 6, 2000
First, I must start by noting that Matt is a friend of mine. I am also a knife dealer and work with Matt in this. That being said, I was as impartial as possible in this review as I believe that any other approach is simply advertising and not a review (and hence, does not belong here).
Model: Camp Bowie.
View
Physical Specs: Overall Length 11 7/8” Blade Length 7” Blade Width (at integral guard) 1 ¾” False Edge Length 3 ¾” Blade Thickness3/16” Weight (don’t know – need some scales!)
Materials: Blade steel is 1095 heat treated to mid 50’s RC according to Matt. Handle material is Green Micarta. Handle pins/thong hole liner are brass.
Sheath: Kenny Rowe Swinger model. Customized with thin kydex liner and initials. This sheath is the nicest leather sheath I have ever owned and a classic in it’s own right. Kudos to Kenny Rowe for this masterpiece.
Finish: The knife came with a very attractive hand rubbed finish. Primary edge was razor sharp. False edge was sharp (but not actually sharpened by Matt – the bevels just meet). Handle scales are perfectly symmetrical and the Micarta is both attractive and well finished.
This knife came to be mine as a result of a post Matt made in the Maker’s For Sale Forum at Blade Forums. I contacted Matt and asked that he finish up the Camp Bowie model for me and have a sheath made with my initials. Matt agreed to do so and was extremely easy to work with through our numerous emails. I asked Matt to make the knife such that it would be a good general purpose camp knife. We decided, therefore, on 3/16” stock instead of ¼” and on 7” blade length as optimal. I asked Matt to heat treat the blade such that it would be easy to sharpen in the field and would be tough above all else. Matt agreed to make the blade a little less hard than his standard 1095 for ease of sharpening and enhance toughness. The kydex lined sheath, although more expensive than standard, was also chosen so that the knive can be stored in the sheath with no fear of problems due to leather which sometimes arise during long term storage. I am happy to report that this knife is not likely to see any long term storage!
Last week the big moment arrived and a package from Matt arrived containing two knives – the Camp Bowie reviewed here and a black micarta handled Razorback. I eagerly, with trembling hands, unwrapped the very well packaged Camp Bowie and sheath. I have to tell you that it was love at first sight. Were it not for Matt’s insistence that I work this knife hard for purposes of giving him feedback on it the knife would still be a virgin! After much persuasion, however, I did undertake some non-scientific testing.
The knife handles quickly – balance very close to the integral guard formed by the blade. This made precise stabs and chops very easy despite only just picking up the knife for the first time.
Wood chopping: I chopped twice through 2x4 pine. I noted that the knife was very accurate and that the handle ergonomics are excellent. During full power chops the knife was comfortable and grip secure. Matt prides himself on his handle design and rightfully so, I found. After making my way through the two boards I decided that 3/16” stock in a 7” blade is not optimal for heavy chopping chores. The same qualities that make the blade extremely quick and responsive also prevent the knife from being a great chopper. That being said, the knife had no problem cutting the two boards in half – just required more chops than would a 9” ¼” stock knife or a H.I. Khukri for instance. After the two boards were done the knife would no longer shave hair but would scrape hair easily and still have a very usable edge. No edge deformation of any type was evident.
Tow strap: I next proceeded to steel the knife on a Henckels 4 Star kitchen steel: 10 strokes on each side. This brought the knife back to a razors edge. Then I cut an old style (thick fabric type) tow strap into pieces with the Lamey knife. The knife cut aggressively into the fabric strap – as well as a razor sharp CRKT M-16 large Tanto folder with 1/8” stock blade. I was very pleased with this performance. After about 10 minutes of cutting on the tow strap the edge was still razor sharp. No edge deformation of any type was evident.
Cardboard: I then sectioned up numerous cardboard shipping boxes in which I receive inventory. I sliced cardboard boxes for approx. 30 minutes. The Bowie cut aggressively into the cardboard and sliced easily through the board – much better than ¼” thick knives such as my MD ATAK for instance. This I attribute to the 3/16” stock. After this cutting the edge was blunted somewhat but not damaged in any way. I steeled the knife again (10 strokes per side) and proceeded to the:
Cardboard Slashing Tests: Here I took cardboard police pistol targets (standard box thickness cardboard) and performed slashing tests. The Bowie was extremely quick and accurate. The slashes were deep and effortless. The unsharpened false edge also produced some very deep cuts into the neck of the cardboard target – 3 to 4” deep on backcuts. My impression from this test is that the Bowie, while a utility design, has definite potential in a defensive role should the need arise.
Wood Whittling: The Bowie took deep slices out of 2x4 pine pieces. The knife cut aggressively and deeply into the wood. This knife performed better on wood slicing tests than many of my 1/8” stock folders and as well as any of them.
Stabbing Tests: I finally managed to find a weakness in the Bowie! I stabbed the knife full strength into pine 2x4 boards and then pryed the tip out sideways. After the second stab I bent the extreme tip of the knife slightly by prying it free of the board. The bent portion is the last 2 mm of the blade. No further damage was caused by repeating the test 8 more times. I did not attempt to fix this due to wanting to show the tip to Matt as is. The tip on the knife is very fine and this test bordered on being abusive. The knife is very safe to use for stabbing due to the integral guard formed by the blade. You WILL NOT end up sliding onto the blade of this knife no matter how hard you stab into an object.
Meat Cutting: The Bowie was used to slice up several pounds of semi thawed frozen boneless chicken breast while assisting my wife with dinner preparation. The knife performed this task effortlessly. The Bowie will definitely serve well in it’s intended role as a food prep knife in the camp.
Brush Clearing: I took the knife/sheath on a 6 mile hike along a border trail at a local State Park and used the Bowie to clear small brush obstructing the pathway. The knife chopped effortlessly through branches (live and dead) in the 1 to 1.5” diameter range. The norm was 1 chop required to sever the branch. Here the speed and accuracy of the knife made up for a lack of mass as compared to a longer or thicker knife. The sheath was exceptionally comfortable on the hike and also on the ride to and from.
Sharpening:The Lamey Bowie responds extremely well to steeling with a standard kitchen steel. The knife also sharpens well with the Spyderco Sharpmaker ceramic stones and responds well to a final stropping after the Sharpmaker.
Conclusions: The Matt Lamey Camp Bowie is a very attractive knife. The knife and Rowe sheath have become favorites as I use them. The knife offers very good performance and will serve well as a utility knife which can double as a tactical knife if need be.
Kevin Pensinger
The EDGE Equipment
sales@theedgeequipment.com
Contact The EDGE for your custom cutlery needs!
Great initial impression and review. I like the very wide blade look of that knife. I would think that it would add some weight and improove cutting performance somewhat. What is the Rc of the edge of the blade? if you know, that is.
Kevin,
Excellent review! Very well thought out and described
. You tested the knife perfectly for the tasks for which it was designed.
Matt's knives appealed to me from the first time that I saw them here on the forums, and his approach to knife making is right on IMO- his willingness to put his blades on the line for testing and feedback in order to optimize them speaks volumes to me. Now, after your terrific review of his camp bowie, I am even more anxious to receive one of his fighting bowies for evaluation. Matt tells me that its been profiled but not ground yet...Ah well, all I can do is drool for the time being
Mario
Gaucho
Tuvo muy mala suerte...se callo en mi cuchillo.
Very nice looking blade, would it be possible to see a top down view. I would like to see the handle shape. What is the handle security like if your grip is compromised (sweat or whatever).
Regarding the bent tip, about how deep were the stabs and how thick is the knife at the entry point? Did you break the wood out with the pry or did the tip just loosen the wood and slide/pop out.
What is the edge profile? Is it convex or flat ground? How thick is the blade behind the edge and what angle is the edge bevel ground at?
-Cliff
Cobalt, I will get with Matt when he is back in the shop and get the answer to your question. I don't want to misquote him on this important piece on info
Cliff, I will see what I can do to get some additional pics and answers to your questions. I appreciate your interest here and kind of figured I might have a couple questions posed. Thanks!
Kevin
Kevin Pensinger
The EDGE Equipment
Kevin,
Great review! I have on order a camp bowie with 1095 too, and I'm glad to hear that the steel responded well to steeling!
IMHO, nothing beats carbon for a using knife. I'm very anxious to get my knife and see Matt's workmanship, as I have heard nothing but good things about his work!
I, too, would be interested in what type edge is on it. Thanks!
Cliff/Larry,
I had Matt sharpen my Bowie with a traditional "v" bevel so that I could resharpen easily (I have no expertise in resharpening a moran edge).
Matt is trying to talk me into letting him put a moran edge on the knife when I send it back to him for refinishing but I don't think I am going to do so... I like the edge the way it is now
I am still going to have some work to do to get the other measurements for Cliff and my dial indicating calipers are standard, not metric so there may have to be some conversions done...
I am looking forward already to my next trip to the woods with my Lamey.
Kevin
Kevin Pensinger
The EDGE Equipment
Thanks for the "full" review, and i especially appreciate you leaving in the tip bending. I may need to address tip strength on this knife, as the tip is fairly "keen" for a camp knife. Let me know how bad it is and send it back if you want me to straighten it/clean it up etc....
On the RC hardness- I dont have a good tester, i use the indicator file set. Edge is 56-57+/-, spine and tang are low 50's.
Most of my knives are a tad harder, i tempered this one back a bit more as stated above.
Thanks Again.
Matt.
"Eternal vigilance is the price of liberty"
Thomas Jefferson
www.lameyknives.com
Kevin, just try the Moran edge. Since the steel is left tough I can't see fractures being a problem and I would bet that a strop and a steel will go a long way sharpening wise. And of course if you don't like the convex edge, it comes off fairly easy with a benchstone.
Matt about how hard does the differential temper leave the tip?
-Cliff
Kevin,
Thanks for the great review on the Camp Bowie! Are you planning on doing a review on your Razorback as well? I have one of those on order and I'd be really interested to know how it performs. Thanks alot!
Kev
Chubbs,
Actually the Razorback is a for-sale knife so I will not be able to review this one. The knife is 3/16" 1095 hardened a bit harder on the RC scale than my Bowie according to Matt.
I think you will be very pleased with your Razorback - it is a very nice knife.
Kevin
Kevin Pensinger
The EDGE Equipment
Good review, Kevin. I like the look of this knife. How long of a wait did you have on this knife, from the time it was ordered, till you received it?
Harry
Toujours l'audacite!
