First of all, excuse my poor english
How to make an... almost-micarta-G10?... sheath for a NMSFNO with very little means
The idea is to make it laminating a mixture of fiberglass and cloth with epoxy resin, modeling the sheath on the knife itself, a bit quite a Kydex sheath, but cold-working.
The laminate consists of 7 layers: 2 fiberglass, 2 cotton cloth and 3 of Jeans
Impregnated of resin and stacked, then pressed between two blocks with clamps (see photos below)
In a couple of days it is dry and ready.
Here it is, raw and a little sanded. This will be the same board that I will use to make the base of the sheath, which will consist of 2 bits, a flat base and a "cover" with the shape of the knife
The material is flexible, but with enough consistency to be able to screw in it. Trying to cut it and stabbing it, it´s clear that the material is thougher than any leather I have ever seen
With 7 layers and low press, the final thickness is about 3.8 mm, a bit too much, because the sheath will go to 180-190 gr of weigth, but for the Bussé I wanted something "heavy"
The first job is to fill with foam the "gaps" left between the knife and the base, so the resin don´t flow in there, making the sheath too thight, and a PITA to adjust
You must fill in all the the concavities of the ricasso, both bottom and top (which I did not, and was a problem later ...)
Picture of the side of the knife that will go over the smooth part of the sleeve:
The knife and the blocks are wrapped in oiled plastic film
We need to make a rough mold of rubber, or dense foam, in the shape of the knife, to ensure the laminate is well adapted to the knife shape, again same as with the Kydex sheath, but this time putting two layers, one cutted and below, one complete:
In camping mattress, I trace the outline of the knife (see photo, black marker) giving a further 2-3 mm all around, and then substrac a centimeter from the edge side.
This is done because if the "cap" is not well pressed on the edge but at the same time letting a bit of room, later it will not look clean
