How To Lock stick problem fixed!
Hi guys!
The location of lockstick in framelock blades is always a matter of complaint. A buffer can be added to the blade steel to meet the lockstik. The position of the lockstick can thus be fixed. It is prevented to damage it for life.
https://ibb.co/hV9ct9G
Your link doesn't work and I would be cautious going to a link like that to begin with.
First make sure lube isn't on the tang or lockbar. Cleaning these with soap and water or acetone or zippo lighter fluid would help.
Use light application of lube so it doesn't drip onto the area again.
2nd... If that doesn't work you can try #2 pencil. Just scrub it onto the lockbar and blade tang.
3rd you can try black sharpy permanent marker. Like the pencil.
One or the other generally works. But re application is often needed either one you choose.
Carbidize the lockbar may or may not help.
Send it back to the maker or warranty department.
