Low Ride for Blur and Leek
Well, I certainly should have because I've made low riders for both models. I just did two Leek low riders for a guy working in Houston at a knife dealership called Beckwiths Blades and not that long ago but I guess like a lot of work that gets out of here I didn't document it and scan any pics before shipping it out. I tend to post less when I'm swamped and that has unfortunately been the case I think for this one.
On the Blur. I don't know why I don't have it in my computer. I've looked through and didn't find it and again unfortunately I just did major house cleaning yesterday and the day before removing a lot of pictures from my forum to make room for new work. So, there are going to be a lot of red x's for a lot of those old pics.
Maybe the young man at Beckwiths can show you his. The good news is though that I have two Blurs, and three Leeks so I could make these up for you without needing the knife.
Keep in mind that on knives with the options for both tip up or tip down carry that the low rider is specific for one mode only. Hard to explain but that is the case for most. If you need the details ask and I'll explain. :D
Thanks and sorry I don't have pics of what you wanted.
http://www.beckwithsblades.com/
Rather than create a new post.
STR could you make a low rider clip for a blur that will allow left side tip up carry?
Also what is the possibility of making micarta scales for a blur?
Thanks
Zero on the scales. Not going there due to machining needs on the underside.
On the clip. Probably could do that since I think its aluminum handles on those if I'm not mistaken.
STR
yeah the handles are aluminum.
So I would need to send the knife to you to get the low rider clip made?
Unless you can drill and thread it yourself. But even then I don't know where to make the fold over point on the clip to make it sit right without the folder.
I will need you to print and fill out the work order form in post number two of the low rider clip thread which is a sticky post top the page. Until its fixed it kind of cuts off section six and you'll have to pencil that part in if you use the pdf format but its fine otherwise.
Thanks.
STR
Not a problem I was just wondering. Will print it out and get everything sent off as soon as I can.
