M.L.E.K. Low Rider
Here goes my first attempt at adding images. . .
[/IMG]
[/IMG]
Ok, I guess that didn't work. Which link in Photobucket do I copy to post to this forum?
Sometimes you have to watch the way it loads. I forget the exact step needed but at times the http slash and : gets doubled before the www so you have to watch to make sure it loads in there right for the link to work. May take a couple tests with an edit to go back and try again if it doesn't work. Been so long since I've loaded one that way that I kind of forget the details but it has something to do with that I'd bet.
STR
It's more of a blue. I moved to SoCal from the Midwest in 2007 and have never looked back.
I figured so. Nice pics! Thanks for adding them.
To change the subject a bit. I'm just a couple steps away from your BUSTR folder being all done. I made the low rider yesterday but don't like it. I actually forgot until looking that you wanted it tip down. I made it for tip up and I folded it anticipating having to negotiate the lanyard hole so for tip down it will have to be folded in a different spot to satisfy my tastes for how it should look on there. I can use the other one on another folder. I'll make a new one either later tonight or tomorrow for yours and mount it then. Then I simply need to drill the lanyard through the scales and contour them and its all done.
Has a fine lock up, great action and should be ready to mail tomorrow. :thumbup:
STR
