mcusta tsuchi
Hello, I am wondering if you would be able to add a clip to this knife. It is not drilled right now at all. Thanks a lot.
I'd probably have to make a small flat spot to sit the clip down correctly on that one but yes it looks like I could do it. It seems to look to me like tip down would be a bit tricky and if I did get it I may have to struggle more there due to the size of the pivot and tight spaces. Tip up carry seems to look far easier and more convenient for location to me but I'll know more when I see it.
I would need you to fill out and print my work order form from my sticky thread titled Low Rider clips found in the PDF file links in post number two.
Once done mail at your convenience. All the info I need is there and all that you need to get it to me is there also.
Thanks for asking
STR
