STR said:Only real difference is probably in the increased corrosion resistance the S30V models have over the 440V/S60V knives. Edge retention is slightly better in the S30V models also because the edge doesn't tend to roll as easily. But it is so close as to be hardly worth mentioning. The 440V knives I have owned, one of which was a Millie, have performed quite well and sharpened up very nicely even though I got them used.
STR
wwells20 said:I agree, I got some surface rust on my 440v Mili. Not bad but it rusted. I have never had any other stainless rust and even D-2 hasn't. The 440v sharpened up nicely but I've never used the knife hard enough to really know edge retension.
Sal Glesser said:We found that S30 V was better than S60V in abrasion resistance by about 30% (at optimum knife blade Rc). S30V also was about 13% better than D2 in abrasion resistance. S90V was superior to S30V by another 15%-25% depending on edge angle. (We make out own mules, heat treat to factory spec, use our own CATRA (calibrated anually), our own dedicated technician, consistant edge angles (lazer goniometer) and optimum hardness).
We found that S30V was only slightly better that S60V in corrosion resistance. Nowhere close to 440C. (Govt approved Q-Fog tsting).
SteelDriver said:Vassili, where did you find that S60V is 8X more wear resistant than S30V? Keep in mind that S60V is usually a few points HRC softer than S30V.
JD Spydo said:440V is not bad blade steel at all. The 6 Spydercos I own that have that metal I will probably keep with the exception of the Lil T which I would like to replace it with S30V. But the one gripe I have with 440V is that is some of the hardest steel to sharpen I have ever encountered. Even some steels I have sharpened with higher Rockwell C ratings aren't even as hard to sharpen as 440V.
If you have kids you want to punish make them sharpen your 440V blades. They will behave after that![]()
