- Jun 11, 2006
im runing forced air and wondered if i could drill a small hole about 1"-2" away from the forge in the burner tube and tap it for a small tube. i would drip some oil into the burner tube after the forge is running with LP. i would cut the LP back a little and turn up the blower. i was hoping to reduce propane usage when im running wide open. so i would be using oil and propain at the same time. what do you think.
