- Nov 24, 1999
I tried my first kydex sheath today. I ended up with a hunk of plastic resembling a sheath, that I can put a knife into and shake it upside down without the knife falling out of. I also almost ruined a brand new heat gun, almost ruined a knife I almost had finished, and all I got out of it was something nobody would admit to having made. Although my mom said it wasn't bad, maybe I'll hang it on the refrigerator.
In order to start things off right, I drew my pattern on the wrong side of the kydex and cut it out, so I had to make the sheath with the textured side on the inside. I should have quit then, but I figured that was minor.
So I started trying to mold it, only to find out that I had done a bad job estimating size. Yes I'm cheap, and made it too small in an effort to have less waste. Still didn't quit. It was close enough that I thought I could make it work if I messed with it long enough. Messed around and messed around, got it decent. Then I tried putting in a few rivets to hold the end that was good, top one tore out when I heated it up again to loosen it around the gaurd. Finally folded the belt loop over and gave up. Heat gun fell off of the workbench and smashed the tip in. Then I got to looking at the knife. A 7.5" OAL drop point I was almost done with. Rosewood scales, ATS 34. All it needed was some tung oil for the handle and to sharpen it. It was definitely my best knife so far. Only I got it too hot working the sheath and the epoxy let loose at the front of the scales, and they shrank up away from the tang a little. I tried pushing epoxy down into the gap with an exacto knife and re clamping them. I don't know how it will turn out.
My next try will be with a gerber multi tool. I guess it would have been smart to do that in the first place.
So what do I need to do to get this F up fairy off my back ? Silver bullets? Maybe some cloves of garlic and a stake ?
Hopefully I kept it busy enough you guys got some work done today. Anyone care to volunteer for that job tommorrow?
