- Nov 26, 2001
Well guys, I think I've found a really good tip and I'd like to share.
I posted a few days back about cleaning out the pivots of my 43, I tried wd-40 and it was a mess. Dont use wd-40 unless you want to wait 3 days for it to dry.
Find yourself some good jewelry cleaner (I use "Hagardy Jewelers Cleaner") These normally come with a small brush, but a toothbrush (not your teeth one, get a new one
) will work just as well.
Take a q-tip and dab on the cleaner like applying oil, apply about three times the amount you would use if you were oiling it. Now take your brush and scrub all around, I scrubbed for a good minute. Then I applied more cleaner and let it sit for 10 min. After letting it sit come back with a spray bottle of rubbing alcohol and blast the pivots with a good hard stream. All that build up and old oil will be washed away (do it over a sink, it gets kinda messy)
Now wipe off all the alcohol with a cloth and dab out any from the pivots with a q-tip. I let it sit for a half hour to make sure it all drys. It evaporates quickly, in a half hour its dry as a bone.
Next polish the handles/blade with "Mothers Mag and Aluminum Polish" This stuff is AWESOME. It is 10 times better than Flitz. Use as directed on can. It can be found at walmart and meijer type stores for 5 bucks.
Be sure to tuf cloth the blade, after polishing I've noticed an untreated blade can rust easily. Make sure you treat it with something.
Now do the same to the handles.
Apply your choice of lube (Miltech-1 for me)
And you're done.
My bali is better than what it was when it came directly from BM, it is so nice and smooth now.
I know this sounds corny but it worked so well I had to share.
The jewlers cleaner is safe for more delicate items and stones, so dont worry about it damaging ti or steel. Also rubbing alcohol wont rust metals either.
Hope it works for you
I havent tried the flux cleaner like Chuck has recommended, I would like to use it to compare to this but from what I've seen this gets it all cleaned up so either method should work.
While your at it clean your wifes/girlfriends/moms/sisters jewlrey for extra brownie points. Gauranteed to get you a good Christmas present this year!
And you're done.
