- Sep 4, 2000
hieach,
After a brief ownership period of two weeks I have one and only one criticism of the Sebenza design. This relates to the confusion that exists in the machining geometry underneath the clip. Before my piece arrived I envisaged the clip and lanyard would be removed and stored, to leave the clean pure design I had searched for. True enough the lanyard has been removed but the clip will have to stay attached. Reason for this is the pig's ear that has been created from the initial clean lines, by adding overlapping machine cuts as after thoughts.
The attached scan shows the areas that bother me.
Hole 4 has been there from the start. Good hole I like it. Could not have the integral lock without it.
Profiled recess 2. Added for pocket clip. Nice touch, would probably not interfere with hole 4 chamfer if left alone, but added clearance 3 is needed for correct clip seating. Starts to compete for space with hole 4 chamfer.
Lastly material thickness for preloading the sprung member is considered too thick even with the hidden W machined to relieve thickness on the inside. Further material is removed under the clip, feature 1. This now leaves the surface at 5 totally confused. Is it a hole chamfer, a clip cutout or a feature to control spring stress. The answer is all of them and it looks crap. A consequence of adding afterthoughts together instead of good up front design. Everything else superb
This concludes the voting for the English Jury.
Redrags
Tink
Redrags
Tink
