Ray,
Common sense says me that all talks about mono- or polycrystalline diamonds is not more and not less than very hard simplification. There is no polycrystalline diamonds, each diamond small or big always is mono-crystal. It is impossible to get diamond particle made of more than the single crystal.
In my experience with both sharpeners DMT uses much more consistent size of diamond particles for each grit and this is the secret of precise honing and durability. Another DMT goal is very consistent and durable nickel plating over steel surface what embeds diamond abrasive particles. What do you think about so-called break-in period? Is it the rounding up of diamond cutting edges causing them to cut less aggressively? Wow! it is impossible to round up diamond edges! Diamond shape is constant and invariable. It is also impossible to break diamonds but it is possible to break them out of the nickel plating. Breaking in diamond sharpener user breaks out from the sharpening surface inconsistently embedded say, redundant - abrasive particles.
When I had only one DMT fine/ultra-fine Double Sided Diafold I have reprofiled with it some dozens of pretty hard blades and restored heavily damaged ones. Please take into consideration than nor Diafold as itself neither fine grit are not suitable for edge reprofiling. So this kind of use should be certainly considered as abuse. But this my Diafold still lives and works!
As to Eze-Lap sharpeners I cant evaluate their durability. To
last 30 years and to
work 30 years is not the same. So far I didnt make any Eze-Lap sharpening surface bald and Im sure in long run use they will hold up pretty well. Taking into consideration that Eze-Lap sharpeners are almost half less expensive than similar DMT ones I would dare to say that they offer somewhat more sharpener for each your dollar from average users viewpoint.
Their main drawback is relatively inconsistent particle size in given grit. This provides the feeling of crazy cutting and noticeably less accurate result, especially if precisely honed edge is needed.
So I could say:
- If you want to sharpen your knives to acceptable level of working sharpness for reasonable cost go with Eze-Lap
- If you are mastered free hand sharpening and want to get from your sharpener as much performance as possible definitely go with DMT
Some kind of difference like between Ford and Mercedes...
In another words, want decent sharpener get Eze-Lap, want
excellent sharpener (see thread title) get DMT.
However all said is just my humble opinion, as usually at least...
