Need some 3/4" thick Nickel Silver
On the Lively knifemaking video, Marianne made some coin silver with a touch of copper wire. Sprinkled on a bit of flux and, voom! Silver! Oh dang thats right, you said nickle silver... doh!
Hey I know Admiral has 201 nickle... maybe if you gave them a call?
Originally posted by Mark Williams
Anybody know of a good source? Thickest stuff I've seen is 3/8"
Thanks
the last I got was from TKS
1/8" plate..and I have some .080 also
You may have to get your scraps together and smelt a quantity in the size you need. It is not very difficult to do.....
Doc
Mike Hull was cleaning out some NS a while back - had quite a stash, IIRC. Maybe he knows a good source.
The stuff is quite expensive lately...:(
That was sold some time ago, and there was no 3/4" thick stuff.
If anyone has the book, "How To Make Folding Knives", by Centofante, etc., in the back, there is a list of suppliers, one of those is a manufacturer of Nickel Silver.
From what I understand, it's way cheaper from them, than most supply houses sell it. :confused: :eek:
Hadn't thought about smelting my own. That's a good idea. May as well cast the part I was going to grind while I'm at it. Oh great, now I need casting supplies.Aint it just grand?:D
If you find a foundry supply near by you could just purchase a German Silver melt ingot and saw it to what ever size you want. As to pins of the same material I just saw off a small piece and silver braze it to a short piece of steel rod as a holder then using a mill or a lathe turn it to size.
Sheffields in central Fla has lots of sizes of nickle silver, with high nickle content so it doesnt turn yellow with age, that is a big problem with a lot of that stuff.........dont know if they ever got a web site but they are listed in the Knives Annual etc.
E-mail sent Alan,
Hey Bill I only need a piece 1 1/4 inch long.
Thanks for the info Tom. So what percentage of siver is the good stuff 18% ?
I wonder if the percentages are weight or volume?
This could be fun:D
Thats alright Bill,
I'm going to forgo the machining and just cast what I need. Sounds more fun than grinding it anyway:D I appreciate it though.
Alan & Mark - I am unfamiliar with casting NS (but very interested), so if you don't mind, could you post your results when finished?
Here is what I have done in casting so far (unfortunately no pics). Aluminum and brass can be melted down in a very simple home made furnace that runs on charcoal, and a blow dryer (no kidding).
You need a 5 gallon steel pail, some play sand, and fireclay (available from grainger as furnace liner refractory in dry powder form). The rest is easy and with a nights fire run inside it will bake to a relatively hard (fire brick hard) liner.
I made a crucible from a 4 inch diameter steel pipe, and it works great. I just fill the thing up with whatever scrap I am going to melt, and fill the rest of the furnace with charcoal and light it off. Takes about 15 minutes to melt 5 to 6 pounds of aluminum, and brass takes a bit longer.
There are many good, cheap books on the subject, and all are worth more than the info you get from them. I got mine along wiht alot more from Lindsaybks.com and am about to get one on a propane fired forge for about 10 bucks I think.
I bought into the whole thing for my motorcycles, but I have thought of alot more uses for the furnace with the knife making. I have thought about ornate bolsters and gaurds, and this would be one way to accomplish all of that without a ton of work.
If you would like more info from me you can email me at dns@knology.net.
Doc
Mark, Bruce Evans is starting to cast his own N/S. I know he had to come up with a new burner to get the heat to puddle it. It melts at a higher temp....
Wasn't the guard on his latest little bowie cast Nickel silver? I would guess if my forge gets hot enough to weld it should be hot enoughj to cast I hope. If not I know my coake forge will puddle steel if I dont pay attention so it will work.
Doc - email sent. Thanks!
I never thought of casting brass or nickel silver. I knew you can cast bronze, tin, etc.
Learn something new every day...
