- Jan 31, 2009
Fallkniven have a launched a new knife called the Kolts Knife.
From their site:
And now for the pics
Fallkniven wrote:
I like the idea of a small fixed blade with a slim sheath designed for pocket carry. But wheres the hole in the sheath for neck carry?
Another small concern might be the little sheath-tab that clicks onto the guard. Being zytel, it will probably wear down over time, although it might take a VERY long time before that becomes a problem.
All in all, i like it :thumbup:
From their site:
The KK knife (the Kolt Knife) is a traditional designed knife where the clean lines dominate the blade, the handle and the sheath. The history of the design goes back to the times when the knife was a common tool in your daily life, no matter if you were a hunter or a farmer. The knife is not intended for waist belt carry. Instead, it is intended for parts of the body where access to the knife is at best, like in your pocket, or around your neck. By offering a safe, comfortable handle, and a very strong blade with an extremely sharp edge, the non-aggressive design provides a knife which should fit any hand, and any task. The safe click-lock, hygienic zytel sheath protects the edge and stores the knife safely when off duty.
Steel
Satin finish laminate 402J2/CoS steel, HRC 60.
Edge
The edge should be a convex, pretty thin so called ICE edge, improved convex edge.
Blade
Wide, hidden tang construction, lanyard hole of standard size.
Handle
Thermorun handle with checkered sides.
Crossguard
Black stainless crossguard, securely fastened to the blade tang. Since the sheath will lock over the crossguard, it’s important that the crossguard has got the same length and shape from sample to sample and also that it cannot be removed.
Sheath
The sheath is in injection molded polyamide (zytel) where a lever is locking over the crossguard. The sheath has got a thumb press notch for releasing the knife from its sheath on top, the release power should be equivalent with the force of around 10 N (10 kp) or 1 kg. This force is adjusted with the thickness and length of the locking lever of the sheath. The sheath is made with small tolerances for avoiding the edge to faulty cut in the sheath.
Mod. KK
Total length: 185 mm (7.3")
Blade length: 85 mm (3.35")
Blade thickness: 3.85 mm (0.15")
Tang: Broad, Hidden
Weight (knife): 84 g
Steel: Lam. CoS
Blade hardness: 60 HRC
Handle: Thermorun
Sheath: Zytel blade-cover
