- Nov 27, 1999
This is one that I started a while back. It is stacked Zebrawood on an iron sleeve. It's been an experiment from the start. I had never tried the stacked handle before and I tried a long liquid nitrogen soak for the 5160 blade. After edge tempering I let it stand in the liquid nitrogen the full 12 hours. I triple quenched after.
When I did the brass rod test I found that 325 was not enough heat. That is my high end temper normally (at least by my ovens thermostat) At 360 it brass tested fine.
I didn't expect much difference but I was really suprised. The grain is amazing and the edge it took was a something else. I'm going to start using this on all my working knives.
When I shaped this grip it was for my hand. Over the years I've managed to get shot in both hands (and the left arm). My right index finger is slightly crippled so fingers 2,3 and 4 do 85% of the gripping. This is a perfect fit for me.
The handle is made of Zebra wood, German Silver, Stainless, A red file folder that I swiped from my bank, Black ABS, Brass, Deer Antler and Elephant Ivory. The file folder was soaked in Poly overnight and pressed between two pieces of Kydex to dry. Spacers were cut from that sheet.
Finish for the wood is the recipe. It was soaked in the hot mixture for 8 hours and it appears the beeswax got completely through the wood.
I'm not sure why the buttcap looks oversize but it is flush with the spacers. This has been a fun knife. I may keep this one,
